Het is nu 20 Jun 2026, 09:53
 Titel: Vittorazi Moster 185 paramotor engine
BerichtGeplaatst: 09 Aug 2010, 17:17
Vitorazzi describe their Moster 185 as a "plug-and-play", lightweight (12.9 kg), streamlined and compact motor, which offers an amazing 75kg thrust.
The motor offers 25 hp at 7,800 rpm, with a "regular, smooth and gentle thrust to a maximum of 75 kg (130 cm prop) or 70 kg (122 cm prop). They describe its level of vibration as "almost imperceptible" at all speeds and the torque effects as low, because of the weight distributuion and the dimensions of the motor. It is also surprisingly quiet, and has a cruising fuel consumption of 3.5 litres / hour.
The Moster 185 is recommended for all-up weights of 100 - 160 kg.
www.vittorazi.com
