Het is nu 20 Jun 2026, 09:52
 Titel: Home built four stroke Paramotor
BerichtGeplaatst: 24 Nov 2010, 17:32
This is a step by step photographic record of my home built paramotor. I based the design (engine) on the very popular 'Bailey' paramotors. I started by aquiring two 125cc scooter engines, stripped them down and machined what was needed to convert them for use in a paramotor frame. this may sound easy but it actually took me quite a long time. The pulleys were off-the-shelf items but may need to be changed to get the required gear ratio's correct later on. The paramotor is using a 1.3m prop. The wiring harness was made utilizing the standard scooter loom.
I built the frame using aircraft grade aluminium.
Once the safety cage is finished i will try a thrust test to see if I will need to increase the 'cc' of the engine, Bailey started out using 125cc engines but soon realized they needed more power.
I'll keep you up-dated.
