Het is nu 20 Jun 2026, 09:53
 Titel: Wat een mooie apparaat om te zien. Flycocoon
BerichtGeplaatst: 12 Jun 2011, 17:40
Flycocoon electric paramotor in production:
The Flycocoon electric propulsion system for paragliders, a prototype of which was seen in the sky at the last Coupe Icare festival, has recently gone into production. [More...]
It uses Flytec's electric motor, and a a bullet-shaped fibreglass cockpit. The battery sits at the front of the cocoon, near the pilot's feet, to counterbalance the weight of the motor and propeller at the back. The whole thing weighs around 35kg, and is foot-launch and landable.
Its Swiss designer, André Lecoultre, describes it as an 'ascent aid', rather tha a paramotor as such, and it offers climb rates of 1.5m/s, but only for 20 - 40 minutes, after which it needs recharging.
When it's switched off, though, its aerodynamic design means that it does not reduce the performance of your glider as it would be when flown with a free-flight cocoon harness, as long as you are flying it within its weight range. This makes it well-adapted for its intended use which is to boost the duration of a paraglider flight, rather than to buzz around for hours under power, as a paramotor might.
Despite its fairly bulky appearance, the Flycocoon can be carried on the roof of "even a small car".
The price tag is in the region of €10,000, and it comes in yellow, red, blue or white.
http://www.flycocoon.com
