Het is nu 28 Apr 2024, 19:28
 Titel: Polini Digital Racing System paramotor rev counter
BerichtGeplaatst: 19 Jan 2012, 15:53
Polini’s Digital Racing System (DRS) is a rev counter and run-time logger for paramotors, compatible with Thor 100 and 200 engines.
It can be bought with the option of a cylinder head temperature (CHT) sensor. The upper RPM and CHT limits can be programmed into the device, and an LED will flash if either of these are exceeded.
The DRS automatically switches on when it detects a signal from the ignition, and an auto-off function preserves battery life.
It can be retrofitted to Polini’s throttle handle.
With CHT, the device costs €165, or €130 as an RPM-only sensor.
http://www.polini.com
Gebruikers in dit forum: Er zijn geen geregistreerde gebruikers en 57 gasten
