Het is nu 04 Jul 2026, 13:18
 Titel: Polini paramotor throttle controller
BerichtGeplaatst: 18 Apr 2011, 17:34
Polini have a new manual throttle controller that can be used with any paramotor engine.
Its small and ergonomic design fits easily in the hand, where it can be secured by a hypoallergenic velcro band. Its construction from thermoplastic reinforced materials makes it tough and durable, withstanding crashes, scratches, corrosion and sudden temperature changes.
The steel sprung throttle trigger instantly recoils to remove throttle if you let go if it, and the red power cut button is positioned on the top of the handle, to ensure you can't accidentally hit it and cut your engine.
There is also the option for an electric start. It requires two buttons to be pressed at the same time, again a safety feature designed to avoid unintentional start-ups.
The throttle control is supplied with either a fixation kit for a Polini Thor engine with Walbro carburetor or d.24 Polini PWK carburetor, or a universal kit for all other engines.
www.polini.com
