Het is nu 04 Jul 2026, 13:20
 Titel: Paramania Wing Bag
BerichtGeplaatst: 15 Aug 2011, 18:18
Paramania have made a versatile new paraglider quick-pack bag and rucksack that work together as one unit which they call the 'multibag'.
The rucksack has a reinforced, rubberised, waterproof base, an easy-access full-zip front, and a pocket in the lid. Fold-away straps make it airline-travel friendly and prevent it from snagging on things when you slide it into the boot of your car.
Inside the main rucksack is a detachable inner bag that opens out into a large field-packing bag, and then draws up to form a protective inner bag. It is made from UV-resistant material that will protect your wing from the sun, and has mesh panels to allow any moisture to escape. A hook has been sewn in so that you can hang it up to let it air out properly after those dewey, early morning flights!
